Boxes in plenum ceiling
raider1
Logan, Utah
300.22(C)(2) (2008) and 300.22(C)(3) (2011) Address equipment located in plenum ceiling spaces. This section requires the use of metal boxes or non-metallic boxes that are listed for use in a plenum.
Chris
jimthesparks
Chicago, IL
Chris
The way I read 300.22(C)(3) is that only the non-metallic boxes need to be rated and any metallic box is fine. Am I reading it correctly?
don_resqcapt19
Illinois
retired electrician
As far as I know the only requirement for "plenum" boxes and "plenum" flex is found in the Chicago City Code and in some of the suburban codes in that area. There is no such requirement in the NEC.
