Each USB port has 2.4 amps. Enough to charge an iPad!
So is there one power supply or one 5.8 amp power supply?
my response was not to as whether or not it could charge an I phone, it was to bring attention that the conductors in a USB cable could cause a fire if they are too small for this amount of current, I think I remember something about 28 AWG in them, the NEC says for a 27 AWG is .5 amps. Has this even been looked at? if products are supplied with these smaller cables then the only out is to supply with your outlet a heaver cable, if the power supply is a single one capable of 5.8 amps, you must find out what the available short current is that can be placed on these cables, and provide a short current protection device that would limit that available fault current to a safe level, if not your opening yourself up to a lawsuit if a fire was to occur.
I know of one heating repair guy who set a house on fire because he used Cat-5 for a thermostat run, and we think that 40va. is not allot of power but it still produces over 1.6 amps @ 24 volts, and Cat-5 can get very hot with that amount of current.
If you notice I'm not even questioning the 15 amp receptacle, as it is the low voltage side that many seem to not realize how fast you can get into trouble with because of the higher current with undersize wires.
