james_mcquade
hi everyone,
I ran across a situation when my dryer quit over the weekend and worked on it last night.
One of the conductors connected to my dryer element broke loose fron the electrical conector. Not that odd i suppose, it has happened on other electrical equipment in the plants i work at, except the wiring looked like battery acid was poured on it and eat away at the connection point. the terminal and wire was green and some of the wire was a rusty color. Add to that the fact that 2-3 inches of wire insulation was melted and pulled away from the wire. I have inspected and cleaned all terminals, thermal sensors, and heater element during my inspection and cannot determine why the wire was
eat away. All other terminals looked good.
My question is, has anyone else run across this problem, and if i get the dryer going again,
should i keep using it or replace it since it is 13 years old?
thanks in advance,
james
thanks in advance,
james
