Pierre C Belarge
- Westchester County, New York
This is all hypothetical:
Lets say there is a 10 story building, all concrete.
There will be a transformer installed in an electrical closet located on each floor.
The GEC for the SDS (transformers) is required to go to steel or the water pipe within 5 feet of entrance to the building.
Since the building is all concrete, one would have to bring the GEC from the water pipe up to the SDS.
The NEC also permits a common grounding electrode conductor with taps permitted off of the common GEC to the transformers.
MY question:
Can one install the GEC up to the 8th floor and tap off of it 3 times on that floor to supply the transformers on the 8th, 9th, and 10th floors?
OR
Does the common GEC have to be run up to the 10th floor?
MY question:
OR
