We are on a project that consist of 30 apartments on 5-floors,the apartments have individual 125amp single phase panels for each tenant.These panels are fed from the main electric room in the basement-it was called out on the plans to feed the panels with 2/0 MC cable-which we have completed.Heres the issue:Each apartment has a heat pump-unfortunatly they were installed ,before we realized they were 3ph.The mech.contractors have already priced replacing the units or components to go to single phase-however it is not only very costly but due to the units already being plummed -it would void the UL listings.We also priced phase converters-but the owner does not want to deal with the maintenance of the converters.The engineer has asked us to look into the possibility of using the un-insulated condutor in the MC cable as the grounded conductor,and using the MC jacket as the EG.We are trying to work with the engineer(he is bearing the cost of the rework),but I cant find where this type of design would be code compliant.Any thoughts?thanks for the help...
